data error through rs232 in cRIO 9074
In the project being developed we have a pair of motor drivers which use ascii codes from the parallel port. The drivers where cobtrolled with a palm that broke down recently.
So we started programming the software with labview, the program works with visa and a usb to serial and serial to parallel converter. But the motors move extremely slow
When trying to implement the same software to the crio using the rsr323 port abd the same serial to parallel converter we cant make the drivers to work. They only move in one direction no matter what code sent.
The codes sent are 20 and 21 for one motor and 40 and 41 for the other.
Anyone have any idea of what ia happening?
(6,625 Views)
 Hi danielfede
Are you using any of the examples on LabVIEW for serial communication? Did you configured the serial port within the controller?
Here are some useful resources related to port configuration on RT controllers and an example for serial communication:
Why Are the VISA Resources on My cRIO System Not Displayed As Execution Targets in LabVIEW?
http://digital.ni.com/public.nsf/allkb/CBD27C15C3357295862572420068E6B1?OpenDocument
What is the Maximum Baud Rate for the Serial Port on the CompactRIO Controllers?
http://digital.ni.com/public.nsf/allkb/06304FEBA0DEFDE98625710600787CA6?OpenDocument
Compact RIO Operating instructions and Specification (Page 13-14)
http://www.ni.com/pdf/manuals/374639e.pdf
Serial data transfer between CRIO and Host
https://decibel.ni.com/content/docs/DOC-3816
Please post your code if possible. Maybe you are using code that is not permitted in LabVIEW RT.
Luis S
Application Engineer
(6,613 Views)
Hi I have similar problem with servo drive
the drive have ECHO mode which reply every command it get
When I'm connecting the servo drive to the PC with RS-232 to usb it's working great using labview and all commands are extctly as i send them
but when i connect it to compact rio rs-232 port the echo of my command is distorrted, for example if i sent command "ACTIVE" i can get back "ACTITE" which the drive doesn't recongnize.
for some reason there problem with commincutions using cRIO rs-232 while PC usb to rs232 work fluently with the same program and same settings
exaqmple of the problem:
serial setings
the
Drive: Servotronix CDHD-0062app1 (120/240 VAC)
cRIO: NI cRIO-9076
software: LabView 2013
usb: NI usb-232 188345B-02
PC: HP PRO i7 3.4 GHZ, 4GB ram
OS: windows7 64bit
Thank you
Or Hirshfeld
אור הירשפלד
(5,196 Views)
Is this a problem you get with only certain commands, or every command that you send?
Are you able to try it with a different servo drive, cable, or controller to see if the problem persists? If it is a problem with the controller, you might want to see if other serial communications produce any errors.
(5,151 Views)
