error 1950678977
I was working on my LV code and suddenly, when deploying the libraries to the cRIO I got this error message that does not allow me to run the VI.
Deploying NI_EP_Power Quality.lvlib:EP System Info.lvclass:EP System Info.ctl\\10.59.16.211\NI_EP_Power Quality\'EP System Info.lvclass'\'EP System Info.ctl' deployment failed (error: -1950678977, LabVIEW:  (Hex 0x8BBB003F) Unable to deploy the library because the name is reserved. You cannot deploy a library named "System", "LV", or "FP". You also cannot deploy a library with a name that starts with "NI_".).
I had not this error before. I tried to run the built-in example of power quality applications, but the same error again!!
could you help me with this issue??
thanks!
(5,367 Views)
I had a chat with Miguel about this issue, and there was a shared variable created in the NI_EP_Power Quality.lvlib by an accident. We deleted this shared library and it could deploy again.
Best Regards
Anders Rohde
National Instruments Denmark
(5,348 Views)
