error -200077 occured at DAQmx start Task
I am using NI cRIO 9047, Labview 2018, I have a module NI 9216 on Chassis for reading tempreture .
I am  want to change the sampling rate and want to do Synchronisation for 4 RTD . But error -200077 is coimg up. (even tried changing current excitation source for internal and external).
even ,same blockdiagram is working for Vibration sensor fro accelerometer in the NI231 for same Controller.
I am attaching the blockdiagram and Error
Message 1 of 10
(3,124 Views)
You will probably need to reduce the sampling rate to its supported speed
The maximum sampling rate NI 9216 supports is 400S/s, which is less than 1000Hz.
http://www.ni.com/pdf/manuals/376921c.pdf
Message 2 of 10
(3,062 Views)
Hey thnxx
 I did redueed the sampling rate to even 2 samples / second .But, same error comes up
Message 3 of 10
(3,052 Views)
When you changed the excitation to Internal, what did the error message say? It should suggest you change some different property.
Message 4 of 10
(3,039 Views)
it Shows same error , I did changed the current excitation to internal.
I am attaching  all the Setting i have put in the Clock
Message 5 of 10
(3,037 Views)
Can you add Simple Error Handler at the end of your code so that it shows a popup?
Message 6 of 10
(3,031 Views)
yes it is already  at the end of the blocks
see the attached message
Message 7 of 10
(3,029 Views)
Can I see the screenshot of your main VI and the subVI? Do you have teo different VIs?
Message 8 of 10
(3,021 Views)
im not using subvi , only one VI is there
Message 9 of 10
(3,018 Views)
hey
got any solution?
I am using pt 100 for NI9216 card in cRIO 9047,
with same Code in my other module NI 222, works well for accelerometer sensors.
Message 10 of 10
(2,993 Views)
