fatal server error: ...
Hi, I was installing a example program from the book "Labview graphical programming chap. 22" when I got the an error when I tried to reboot the system after the install. I use VMware and redhat7.3 kernel 2.4.x. You can find a screenshot of the output in the attachment.
Can someone help me?
thankx
hans vanherck
hans.van.herck@cit.be
(3,264 Views)
Hans,
I doubt that this error is part of LabVIEW. It strongly looks like a SVGA issue with VMWare (which I have used on both Linux and Windows). Just installing an example program should not have this effect. Was there any other software that has been installed since the virtual machine was rebooted? I would check there as well.
Randy Hoskin
http://www.ni.com/ask
(3,264 Views)
