fpga Standard Deviation calculation - any examples?
Im looking for a way to implement 'Moving Standard Deviation' into the FPGA module.
Are there any examples out there?
I'm using cRIO-9012 chassis.
Yuval
Message 1 of 20
(7,933 Views)
how many data points are you considering?  since the algorithm requires a pass through all the data for each new data point, it will be cycle consuming.  how fast does it need to run?
Stu
Message 2 of 20
(7,919 Views)
I don't know much about the algorithm, but from what I've seen it seems like just a few simple calculations.  It doesn't seem like it would be too tough to implement using the numeric palette calculations.
http://www.transitionstrading.com/mstd.htm
Message 3 of 20
(7,905 Views)
Sorry, the algorithm does NOT require a pass through the system.  is the same calculation as computing the AC RMS value of X which can be computed point by point on a fairly arbitrary set of data.  You do have to keep the set of data around though.  There is a built in calculation of standard deviation pt by pt that will show you an implementation but it is not coded for FPGA.
Stu
Message 4 of 20
(7,896 Views)
I've calculated variance and standard deviation in FPGA using FXP math toolkit.  Attached are the VIs.
Message 5 of 20
(7,886 Views)
Thanks very much to all of you.
I will look at it today and come back with the results.
Yuval
Message 6 of 20
(7,878 Views)
Whenever i code an FPGA algorithm, i create a test case with known inputs.  I am not sure if you did for this
code or not but i put together a test case that does not produce expected results.  I am not sure if i implemented the
your code correctly but you can check it out.
Stu
Message 7 of 20
(7,861 Views)
Many thanks Stu. I'll be back with results.
Yuval
Message 8 of 20
(7,858 Views)
I did have a test project. Here it is.
Message 9 of 20
(7,846 Views)
Your test vi was wired wrong.  I fixed it.
Message 10 of 20
(7,845 Views)
