fpga
 I am using only one DMA fifo to write  an array (array size=32 elements).array elements are also contstant U32.compilation could not completed due to this message.I am not overcome with this problem.
actually i m testing a DMA fifo writing operation with 32 channels @50 khz(Simulation Mode).How can i test this with any NI AI module.
*                         Low Level Synthesis                           *
INFO:Xst:1730 - XST has found some RLOC properties in element CrioClockConditionOclkOut which is instantiated several times. To handle this constraint XST will add the property "hu_set CrioClockConditionOclkOut" on each element with RLOC.
Pratima
*****************Certified LabView Associate Developer****************************
(3,145 Views)
Pratima,
You will probably need to provide a copy of your FPGA code and associated LV project with the DMA configuration for someone to be able to help you with this problem.
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
(3,136 Views)
