generate PWM signal using three phase sinusoidal signal
Aren't your sine waves coming from analog inputs?  That would be what you would use.
Randall Pursley
Message 11 of 19
(3,130 Views)
Attached is a picture with a little more detail as to what needs to be replaced when using this with an FPGA.  The number 1024 defines the number of steps the ramp has.  I also scale the ramp by a factor of 4 assuming the inputs are coming from a 12-bit A/D (mutiply by 4 to get 4096 or +/-2048).  If your A/D from you C module is higher than 12-bit then the multiply by 4 will have to be higher as well (16 for 14-bit, 32 for 16-bit).
Randall Pursley
Message 12 of 19
(3,128 Views)
hi
I just solved my problem just after i mailed you the querry(the problem i was facing)
though thank you for this reply .
If i would face any problem further , i would not again disturb you
thanks a lot
regards
avinash choudhary
Message 13 of 19
(3,111 Views)
hello
i want to ask that
i have set frequency of sine wave as 50 hz
but i neeed frequency of pwm signal to be of order 10khz
what modification should i make?
avinash
Message 14 of 19
(3,074 Views)
Your actual update rate for the PWM signal will be the 10 kHz times the number of steps in your ramp.
For example, assume your ramp is 1000 steps, then 10 kHz * 1000 steps is 10 MHz.  With a 40 MHz base clock, you should set your loops to run every 4th clock cycle.
If you want, you can set up your ramp to be 4000 steps and the math will work out to a 10 kHz ramp output if you update every clock cycle.
Message Edited by rpursley8 on 07-07-2008 07:38 AM
Randall Pursley
Message 15 of 19
(3,042 Views)
Thanks for yout mail
but sorry i couldn't get it what do you mean by set your loop to run every 4th clock cycle
could you show the change on the .vi file you sent me
simply i want to set frequency of sine wave to be 5o Hz.
and PWM signal to be order of 10KHz.
regards
avinash
Message 16 of 19
(3,037 Views)
Post your FPGA code so I can show you what I mean.
Randall Pursley
Message 17 of 19
(3,034 Views)
here i have attached my lab view project
you can make modifications
regards
avinash
Message 18 of 19
(3,032 Views)
You essentially don't have an FPGA design.
Attached is a basic FPGA design for PWM.  You will have to change the inputs and output to match your physical setup.
This should, hopefully, get you started.
Message Edited by rpursley8 on 07-07-2008 12:37 PM
Randall Pursley
Message 19 of 19
(3,023 Views)
