how can I get two cameras to aquire at the same time rather than one after the other
I've got (2) PCI-1428 cards, Two Uniq Vision cameras with power supplies, cameralink cables, and IMAQ-D6804 cables. Both cameras are being triggered by the same switch, but they are not grabbing images at the same time. Right now it is triggering one camera as desired, but the other doesn't aquire until after the time-sensitive event. On the next test, the two camera will trade these roles. I am using 2 cards, so they should acquire at the same time. How do I change it so that they grab images at the same time? Thank you for your help.
                                                              Deater
Message 1 of 1
(3,494 Views)
