03-03-2010 02:42 PM
hi how i can use thr FPGA Bitfules in modelsim coz that file model sime cant read it and i cant read from any program coz it rabish
and thank u for ur help
03-04-2010 11:56 AM
LabVIEW FPGA bitfiles are specific to LabVIEW FPGA targets and cannot be used in other software. LabVIEW FPGA is currently not designed to work with ModelSim. If you are looking to build in troubleshooting tools you can implement some simple UI components that tell you if your code is behaving as expected. If you have suggestions on how you would like to integrate these platforms, the LabVIEW FPGA R&D team is always looking for feeback, just post your ideas on the idea exchange.
Hunter
Applications Engineering
03-08-2010 01:33 PM
Hello thamer,
While FPGA bitfiles can't be used with ModelSim today, we are considering this functionality for the future. Can you tell me more about your application and your need for ModelSim? Do you require cycle-accurate simulation?
Gerardo
08-06-2010
08:20 AM
- last edited on
10-11-2024
01:40 PM
by
Content Cleaner
With LabVIEW FPGA 2010, users now have the ability to export their FPGA VIs to VHDL for simulation in ModelSim. This feature also generates a VHDL testbench template for creating a model of your host and environment. You will have to be familiar with VHDL to use this.
Gerardo
LabVIEW FPGA
08-24-2012 08:47 AM
Can I see or export the VHDL Code from LabView?
08-24-2012
10:23 AM
- last edited on
10-11-2024
01:41 PM
by
Content Cleaner
As far as I know this is currently not possible.
