how much difference would it made if previously I use PCI6040E digital trigger, but right now I am using PCI 6036E analog trigger on the same program that has written previously?
Hi tlk20,
First, your connections will not be the same, you will now use the analog triggering circuitry which will start at the specified level. Second, your trigger programming should change.
Could you define little more the question? It will be hard to guess everything just by that sentence.
Gerardo O.
RF SW Engineering R&D
(3,474 Views)
