how to genrate 1k pulses from scxi 1163/1162
sir/mam,
i want to generate the 1k frequency from scxi-1162 and 1163
ie
i want to generate from one card and measure from the other,
please do tell me/send me the details/any example where these cards are used,
i am unable to configure/use these cards with
pci-6025+scxi-1000 chasis+1162/1163,
i wold be thank full to you if i will generate the waves from these cards..
lux.
lux_rcr1@rediffmail.com
dept of it gug pg center yeragera, raichur-584133.
(3,217 Views)
Please look at the shipping examples for these modules. You can access them from LabVIEW by clicking Help >> Find Examples... From the Example Finder, browse to Hardware Input and Output >> DAQmx >> (Digital Measurements or Digital Generation). From here, view the bottom right-hand window to see the supported products for each VI.
Keep in mind that there is no hardware clock for digital operations with an E Series card. You will have to use software timing to achieve your 1000 Hz rate. But you will be limited by the speed of the relays in the 1163.
Let me know if you have any further questions.
Sean C.
(3,207 Views)
