how to get the free space available in CRIO memory
Hi All,
I want to transfer data from SD Card to to RT. How can I get the free space available in RT memory.
Into the pursuit...
Maverick
(3,664 Views)
I am not sure if I understand your question. What exactly do you mean when you say you want to get the free space available? Can you be more specific?
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,661 Views)
You can use NI MAX to see the cRIO controller. Select the top level controller in the tree. In the center window select the "System Settings" tab on the bottom. Disk space and RAM status is available.
(3,648 Views)
