how to read analogue input signal in NI 9201 module using lab view
I am working with Analog to digital conversion using Lab view 8.2 and compact rio controller with input module NI 9201 and output module NI 9263, I want to read the values from input using NI 9201 and  lab view. but at the moment im unable read the values from input and display the results on screen . what should i do????
(3,594 Views)
Well, you need to have a look at the examples. Have you programmed in FPGA and RT? Make sure you describe the challenge you are facing otherwise it is very hard for us to intepret the problem.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,582 Views)
