how to use SCC-ICP01 module in signal conditioning
"I am trying to use SC-2345 signal conditioning for accelerometer sensor output. I chose module SCC-ICP01 module. Based on the manule of this module, i should connect pin 1 and 3,2 and 4 together. But after following this, DAQ board can't read anything. If i only give the sensor output to pin 1 and 2, DAQ can read the value. Does anybody have such experience? Which connection way is correct?"
(3,244 Views)
Hello;
Pins 3 and 4 of the ICP01 have the purpose of connecting the ICP chip sensor to an on board current source.
Maybe your sensor already has a current source, so when you connect it to pins 3 and 4, both currents actuate, creating a different current value that makes the sensor stop working.
Another possibility is that the module is damaged, however, since you can see good readings when connecting to pins 1 and 2, I don't think the module is bad.
Hope this helps.
Filipe A.
(3,244 Views)
