how to write bit value of a holding register with boolean control by modbus?
I can read or write word value of a holding register, but I don't know how to change a bit of a holding register. Is there any function to do that?
(3,232 Views)
There are many ways that you could possibly do this, one method that might work is to use the "Number to boolean array" function.https://zone.ni.com/reference/en-XX/help/371361R-01/glang/number_to_boolean_array/
(3,197 Views)
I have found the function I want. Thank you for your reply.
(3,186 Views)
Hello, can you explain how did you get to write a boolean value into a holding register ?
(1,619 Views)
