intermittent loss of communication with crio
I am running a cRIO application and I intermittently lose communication with the cRIO.  Has anyone ever experienced this problem?  I am not overloading the CPU (I have monitored both the memory and CPU usage with the system manager).  Any other ideas?
(4,181 Views)
Hi Interested,
What versions of LabVIEW RT, NI RIO are you using and what model of cRIO controller?
Basset Hound
(4,179 Views)
I am using LabView 8.5 and my controller is  the 9012.
(4,177 Views)
Both good versions :-).  What is the NI RIO version?
(4,173 Views)
put waits in your loops or use timed loops. Reboot your router/switch. Reboot your crios.
[will work for kudos]
(4,030 Views)
