labVIEW data acquistition
sir we are presently doing a project in labVIEW and part of our task is to acquire the waveform on  a oscilloscope to the computer. The default waveform of TDS 2024 dgital oscilloscope has already been acquired by us . sir we want to make a real time measurement of active,reactive power and power factor of load under experiments for which we'll have to make some VI's can you suggest possible solutions to us.we'll be grateful to you.
REGARDS
yours sincerely
 students of college of technology
Pantnagar
Uttarakhand
INDIA
(3,954 Views)
Lalshah,
There are no predefined applications that will do this and you will need to create some VIs to accomplish what you are hoping to do. It appears that since you want a solution that acquires continuously,  you would need to incorporate some sort of an architecture that pollsfor data at regular intervals. I would suggest you look atthe link below titled "Learn LabVIEW in 3 or 6 hours" which will give you an overview of some basic concepts in creating VIs and a number of programming techniques using LabVIEW for continuous data acquisition and analysis.
 http://zone.ni.com/devzone/cda/tut/p/id/5247
Raj
(3,927 Views)
(3,906 Views)
The Electrical Power Measurement (EPM) Palette for LabVIEW was created for these types of measurements.
David H.
Systems Engineer
(3,895 Views)
