labview FPGA
plz provide me how to dump a code tht i have written as simulation process to emulator one.....
how to write tht in hardware and how to configure tht.......
(3,273 Views)
Hi data acquisition with cRIO,
I hope you're doing well.  It would be helpful if you could provide more information on what you are having trouble on.  It sounds like have written code in LabVIEW FPGA and targetted the code to a simulated FPGA board.  Now you want to target this same code on the actual hardware.  If this is the case, what part of the process is giving you trouble?  Please provide more information on what version of LabVIEW FPGA you have and what hardware you are using it with.  After we get a better idea of what you have done exactly and what you are having problems with, we can try to advise you a bit better.  Thanks!
Thaison V
(3,259 Views)
