latching boolean and shared variable
I am connecting an NI touch panel as an interface to my cRIO.
I plan to use shared variables as an easy, efficient way to communicate.
How do I implement a latching boolean, such as a STOP button, on the touch panel and have it activate just once on the cRIO?
(3,331 Views)
Hi khalsans,
You can use something called a rising edge detector, which basically a polling architecture that detects if a rising edge of a signal has occured.
Attached is a simple rising edge detector in LabVIEW.  It polls the value of a shared variable every 20ms and detects if there's a rising edge (boolean value changes from false to true).
Hope this helps!
Yi Y.
http://www.ni.com/support
(3,320 Views)
