memory.cpp error in pxi 8186 rt
Hi All,
When I ran the application in PXI 8186 RT, after 10 to 15 minutes RT shows "memeory.cpp" error. Let me know when this error will occur and how to overcome it?
With regards,
M.Valliappn.
(3,956 Views)
Hi Valliappan,
Does the error message give you more information as to what line the error occurs? More information on your setup will be helpful. I have heard of the memory.cpp error occurring due to memory leaks. Are you calling external dlls from your LabVIEW code?
Prashanth
(3,942 Views)
Hi!
I also have the problem with the memory.cpp! I built a program with the application builder and when I run this application, I get this error (the message says in line 342) already after one or two seconds. The VI alone runs without problems.
I have no idea why that happens!
Splettstößer
(3,619 Views)
Hello Splett,
Just as Prashanth said before, we definitely need more information about your system to be able to troubleshoot this effectively.  Are you also using a 8186 and LabVIEW RT?  What is your program doing?  Are you using a lot of express VIs?  How about html or help files?  Can you post your error log file?
Have a great week!
Janell R | Applications Engineer
(3,595 Views)
