multiple connection server CANNOT be build as rtexe on sbrio 9636
I am using sbrio 9636. I take the example called "Multiple Connections - Server.vi" And it works OK when the sbrio is connected to the Computer.
But when I generate the vi to rtexe because that I want to start the vi itself when I boot the sbrio. But after deploy the rtexe on sbrio, it cannot work after reboot. The clients cannot connect to server with socket error code 10061.
Message 1 of 1
(4,286 Views)
