ni 9860
Hi I've just tried setting up the the the ethercat 9144 chaisis with an ni 9860 c series module and crio 9035 being the master. But I can't get the module to appear in the project. Is the ni 9860 module supported by the 9144 ethercat chaisis? If not how can I overcome this? Because the NI 9860 can only be used in scan interface mode and I don't wan't to run it on the crio 9035 because then I'll have to use hybrid mode.
Thanks.
(4,733 Views)
Accepted by OA1
Based on the product page, I would say that the 9860 is not compatible with the EtherCAT chassis.  It should work directly on your cRIO-9035 though.
(4,732 Views)
Thanks Crossrulz, I'm going to have to use hybrid mode then it seems. Or is there anything else I can do?
(4,728 Views)
