niFpgaCompileFarm_OpenJob.vi error at Compilation
Hello Everyone,
I try to compile a simple program to my cRIO-9064 (blink a LED, see attached .VI) with a NI9402 module as input, but at the very end, the compilation crash and return me an error (see Error.png):
niFpgaCompileFarm_OpenJob.vi<APPEND>
<b>Vollständige Aufrufkette:</b>
     niFpgaCompileWorker_OpenJob.vi
     niFpgaCompile_Worker.vi:6460001
I have every driver and module needed installed (see screenshot) , I can connect to the cRIO trough my web browser, but I have no idea how I can resolve this error.
I already searched on the forum but no awnser that I found helped me.
Thank you for your help,
Kaliin
PS:I'm running on Windows 7 Enterprise.
(4,030 Views)
Accepted by topic author Kaliin
Hi Kaliin,
The error that you posted is a LabVIEW FPGA compiler error, and should probably be brought to the more general LabVIEW Software forum, not the Real-time Measurement and Control forum (which is more hardware-specific) as it is a general software (on your development machine) failure.
(4,012 Views)
Thank you for your reply, I close the Topic.
(3,995 Views)
Hello!
Did you find a solution?
(1,045 Views)
It was a long time ago! If I remember correctly I simply didn't install what was needed to compile on a FPGA (like a "verilog/VHDL compiler").
So I would advise that you check that you installed everything as required (the NI tutorial are really well done, go through them again?)
Otherwise, if it's a possibility, give a call to NI, they were very responsive!
Good luck!
(1,020 Views)
