operation of the Iotech wavebook using labview
I have had some degree of sucess using the Iotech labview drivers but found it difficult to achieve the functionality and realtime display that I require. Has anyone written some successful code to obtain both control/setup of the wavebook and a realtime graphical output of the data being acquired?
(3,273 Views)
Thank you for posting to the NI Discussion Forums!  I’m not exactly sure from your description what problems you are having.  What do you mean by “realtime” display?  Are you using LabVIEW Realtime?  And if not, when you say “realtime” are you indicating that the data you are receiving from the instrument is invalid, old, or something else?  Are you getting any errors, and if so, what is the exact error message and which piece of software is generating the error?  You mention success with using the instrument’s driver – what functionality of the driver works, and what appears to be malfunctioning?  Many of the drivers that come with instruments contain at least one example program on how to use the driver.  Is the code that ships with the driver (if there is any) able to run on your computer?
I hope I can help out – please let us know if you have any additional information on the problems you are experiencing.
Have a great day-
Travis M
LabVIEW R&D
(3,266 Views)
