output is always -10V
the input signal is between -5V to +5V, but DAQ card output is always -10V.
(3,579 Views)
Answer the questions I posted to your other question and we can help.
If English is problem, use your native language and someone will translate.
Ben
(3,579 Views)
Hello;
We definetely need more details on how you hooked up your system, what type of board you have and what exactly you need to accomplish.
Using Ben's words, if you have problems with English, answer those questions in you mother language indicating what language that is and we can manage to translate that and provide you a better answer.
Filipe
(3,581 Views)
hi .....you must check the default setting of the waveform graph. remove the checkmark and see.
(3,564 Views)
