power line noise of NI-9205
We are trying to measure the output of a highly sensitive sensor with the NI-9205 converter and MATLAB as interface. The signal voltage is typically a few mV ,with a theoretical noise voltage of a few uV). But the signal we acquired is interfered by a much larger noise ,which can be clearly identified as a time-varying power line noise with an amplitude of 20mV, as shown in the time domain plot and the power spectral density plot, which can also be observed in the short-circuit channel. The noise could disappear occasionally.
The DAQ configurations can be seen in the pic: the range is set as ±0.2V, the terminal config in differential mode and the coupling mode is DC.
To find out the potential causes, we used a in-house constructed DAQ converter as a contrast and surprisingly the signal was pure with little noise.The following pics show the diagram of the system and the environment of the working site.
(1,247 Views)
Accepted by topic author Sebastian.Peng
I guess that your sensor is a floating signal source. When using a differential connection with a floating signal source, you need to connect bias resistors. See Table 1 in Field Wiring and Noise Considerations for Analog Signals
You can try to use Referenced Single Ended (RSE) mode to see if the noise goes away.
https://tmesystems.net/
(1,229 Views)
