problem running exe file without labview
I have created a exe in LabView8.0.When i try to run that exe in the pc where LabView is not installed i am getting the
message like this "Application requires a version 8.0(or compatible)LabView Run Time Engine.Please contact the vendor of application to correct this problem"
please help me.
thanks in advance
(3,218 Views)
You need to install the NI LV Runtime Engine 8.0 on the target machine along with your .exe.  Quickest way is to include the Runtime Engine in the installer for your .exe
(3,209 Views)
