problem with comparisons of integer 64 bits with cRIOs
I have come across a problem with the comparison of integers 64 bits on a CompactRIO system. See attached VI file.
To summarize, the comparisons (<, >) seem not to be working correctly with I64.
For example, x > y returns False with x = 2147485648 and y = 10000.
That is certainly related to a rounding of 64 bits to 32 bits...
Am I missing something?
Best regards.
(3,477 Views)
Hi xred
This behaviour was a known issue in Labview 8.6 and has been fixed in Labview 2009. You can find this in the Labview RT readme:
http://digital.ni.com/public.nsf/allkb/8A88D26C529C13A4862576020071DEB3?OpenDocument
You can find it in the bug fixes list with ID 141130
Best Regards
Michiel
NI Belgium
(3,208 Views)
Thank you for answer, though a bit late...
It is now a known issue of Labview 8.6 but it was not at the time I submit it.
Note, the problem was rapidly confirmed by NI engineers and rapidly planned to be fixed in Labview 2009.
Xavier Jaspar
(3,205 Views)
