programatically export max settings to .ini
I would like to programatically export max settings to .ini the same way that the wizzard can in MAX.  I am running LV 8.5 with the 8.7.1f max.
If you cannot help with that if anybody knows a better way to check multiple tasks in MAX aginst a text file (will typecasting work with DaqMX tasks?)
(3,663 Views)
I may be misinterpreting what you are trying to do, but these KnowledgeBase articles are related to your question.
KnowledgeBase 446HGFD2: Import and Export a MAX Configuration Through LabVIEW
KnowledgeBase 2GJJ9SY1:...
Also, open up the NI Example Finder in LabVIEW.  You can do this by opening LabVIEW and going to Help»Find Examples.  Do a search for "max", and you will find the following examples.
Copying Configurations.vi
Generating Reports.vi
I have assumed that your end goal is to port the MAX configuration from one system to another.  Please post back if I have misunderstood your question.
Rod T.
(3,653 Views)
worked like a charm thanks
(3,648 Views)
