property container
hello,
in the attatchment there is an picture of a main cluster with two sub clusters inside.
in the sub clusters are eight switches.
is it possible tocontrol the switch in the sub cluster via property nodes??
markus
(2,996 Views)
If your right click one of the switches and select Create>>Property Node it will create a property node for that switch. If you right click the node and select Link To you can see where it's located in the list (inside the cluster). You can also get a the [Controls] property from the inner reference and use that to control all the switches. You will need to use To More Specific Class to get the boolean properties.
___________________
Try to take over the world!
(2,988 Views)
