"Event case" can't used in "while-case structure" in touch panel module?
I write a UI state machine VI much like JKI state machine, and used it in touch panel module.
When building, labview prompt error "missing VI or C file ". But this VI is so simple!
I suspect it is because I use "event case " in "case structure".
I have search the ni website, and test the AMC library , and the AMC library works!
In touch panel module, Is there something like JKI statemachine?
(5,558 Views)
Hi superlvjf,
I did not get any errors running your code, although I do not have the character sets installed so it did not work correctly. When you get an error about a missing VI, does the error include an error number or the name of the missing file?
(5,524 Views)
I retried, the building error dialog is ....
I use labview 2009 , run-time engine 2009 SP1.
(5,498 Views)
I found some more information on the errors you are getting. There was another forum very similar to this where the solution was to remove any shared variables being used although that does not seem to be related to your program. There is also a knowledge base article here about how a conflict with the mobile module can cause this error. It also looks like there is a second thread you created here. According to that thread your error goes away when you replace the enum with an integer?
(5,494 Views)
If you are developing this for a touch panel, which touch panel are you using? Also, if you are doing this in a project, can you post the project?
(5,493 Views)
This VI is just for test. I attached the test project.
It's a simple project, only contains the EventStructError.vi, and builded for windows CE 5.0 ....
(5,485 Views)
