"Failed to Load Shared Library" error on RT EVS 1464 Embedded Vision System
Hello!
I have this problem when i try to run a .vi application running into my RT EVS 1464
error
I have been looking for a solution and i have found this posible fixes:
Fix 1.
Fix 2.
but none worked for my trouble.
I'm working in a RT EVS 1464 Embedded Vision System, and my DLL file, contains just a simple test summing function, for probe the functionality of DLLs into my RT system.
Please, can anybody help me?. I share all the files, including the Visual Studio Proyect used to generate the DLL.
(3,339 Views)
Not all dlls are supported on RT target. You need to check if the dll you are using is deployable or not using this tool.
(3,255 Views)
