"Server does not support Remote Panels" message on sbRIO-9612
After installing LV 2010 SP1 to fix a problem with TCP close (which it did), it seems that remote front panel functionality has stopped working.  The error message is in the subect line of this post . . .
I ftp'd the new remote panel license file to the target and renamed it LV_RPC.lic.  The Remote Panel Server in the target's configuration is enabled.  I followed the same steps to create the html file and include it in the real time start up executable as I did in LV 2009 SP1 (when remote panel functionality worked on this target).  I verfied that the html file is present in the ni-rt/system/www folder.
Any help is greatly appreciated - thanks,
Al
(5,488 Views)
Hi Alasys,
This KB shows what you need to do to fix this error.  Hope this helps!
Best Regards,
Starla
(5,484 Views)
Hi Starla,
Thanks for your reply . . . Maybe I don't have something enabled properly in my web browser, but I'm not seeing any reference number or link for the KB you mentioned.  Would you mind posting it again?
Al
(5,482 Views)
Hi alsys,
It looks like Starla forgot the link. Here you go.
"Server Does Not Support Remote Panels" Error When Connecting to a Remote Front Panel
<Brian A | Applications Engineering | National Instruments>
(5,468 Views)
Hi Brian,
Thanks for the reply.  I checked each of the possible causes in the KB link and none of them seem to apply to this problem.
While searching around on the NI web site, I came across a LV 2010 known issue: #255627 Remote Panels not working in LV 2010 built executables.
Since the front panel of the VI that I'm trying to serve out is part of the real time start-up application, could this be causing the error?  If that is the case, do you know if/when the next LV service pack or update release might fix the #255627 remote panel issue?
Thanks much!
Al
(5,462 Views)
Hi Alsys,
I would highly reccomend moving away from remote front panels.   Instead, use web services or shared variables to publish infomation to your host.
--Starla
(5,457 Views)
Have you tried reaching the front panel while running the VI on the target in development mode (as opposed to from the rtexe).
I ran into the same issue you were having with LV 2010 (not sp1) and I was able to solve it by changing my remote panel port to 8000 (changed it from 80). You might try changing the port there and going to http://rioipaddress:port/yourhtmlpath
This was with an sbRIO 9642.
Remote panels work from the target both as an rtexe and in the development enviroment.
CLED (2016)
(5,405 Views)
