real time acquisiton and processing of EEG signal in LABVIEW
I'am trying to acquire single channel EEG on LABVIEW based on Arduino board. How can i increase the amplifier's gain in order to get a good signal ??
(3,072 Views)
Is this an external amplifier? Or an on-board amplifier that the Arduino has? What does your hardware setup look like?
(3,028 Views)
Its an external amplifier hooked up with arduino board on A0 GND and 5V.
(3,025 Views)
This forum is usually only supports NI products themselves, so I don't know if you'll get a lot of help directly from here about how to work amplifiers.
But researching how amplifiers work would be a good start!
Here is a basic explanation on how gain works.
Operational Amplifier, Op Amp Gain & Equations:
http://www.radio-electronics.com/info/circuits/opamp_basics/operational-amplifier-gain.php
(3,014 Views)
