reduce memory usage on crio-9053
CRIO-9053 with 9411, 9403 modules
Miniconda/Python 3.9.5 w/ nidaqmx libraries
Free memory: 324MB, used 554MB (with no user application running)
NI MAX shows Linux RT System Image 21.0 is currently installed
I do not use or need to use LabView, just use python scripts to take readings -- that bit is working just fine -- I am just reading a rotary encoder, and setting some lines high to turn on another system.  What I need to do is to drastically cut base memory consumption so I can get a 512MB or 256MB model for development work.
What things can I uninstall to save memory without cutting into things I actually need?  I've attached the MAX screen that shows what was installed when I got the system.
Tempting targets here that look like they are using quite a bit of memory include the DAQmxRemoteService and the NIWebServiceContainer, neither of which I use (I believe).  For the WebService container, however, I'm not even sure what to  uninstall.
Any pointers or guidance would be appreciated.
-Evan-
Message 1 of 1
(1,055 Views)
