sb-rio 9642 default ip 0.0.0.0 remains unchanged
my sb-rio-9642 stopped communication through Ethernet port So I opted for the IP reset option and followed the guideline in its manual to reset the ip to 0.0.0.0 ... But now I am facing a problem. I have tried several times to set the ip address of my choice on the card through MAX but each time on clicking the apply button on the MAX software the card reboots but the ip address remains unchanged i-e 0.0.0.0. plz help!
Message 1 of 12
(7,532 Views)
Make sure you set the ip reset back otherwise it will reset every time it boots.
Message 2 of 12
(7,528 Views)
the initial setting of DIP switches on the board is
Safe mode ON
Console out OFF
IP reset OFF
No App ON
USERI OFF
No FPga OFF
with above configuration i power ON sbrio-9642
I then switch ON IP Reset Dip Switch
I then restart sbrio-9642 through reset button provided on the board
I then switch OFF IP Reset Dip Switch
I open MAX software and enter a network address for sbrio-9642 with the same subnet as on my pc
I press the save button on MAX
The MAX software give a message that for configuring the new IP address for sbrio-9642 I need to reboot sbrio-9642
I click YES so it reboots sbrio-9642
But instead of showing the new IP address that i entered it again shows the old ip adress i-e 0.0.0.0 and the system state remains 'unconfigured' .
PLZ HELP!
Message 3 of 12
(7,515 Views)
i am using labview 2012
MAX 5.4
NI RIO 12
is there any software version compatibility issue with sbRIO 9642.
regards
Message 4 of 12
(7,503 Views)
You may want to upgrade to MAX 5.5.  I think 5.4 may have had some issues around reseting the IP address of an RT target with 0.0.0.0.  If upgrading to 5.5 doesn't help I would also suggest deleting the target from MAX under remote systems, then close and reopen MAX to rediscover the target. Something may just be confused in MAX's cache.
5.5 link - http://joule.ni.com/nidu/cds/view/p/id/4086/lang/en
Message 5 of 12
(7,491 Views)
Thanx a lot JoshuaP for your time and consideration.
we have tried as you suggest and also update our MAX but problem is still here.
upto now we have tried in different ways as follow
changed network cables (cross and straight)
changed system (Desktop and laptop)
changed software (LabVIEW 8.6, LabVIEW 2011, LabVIEW 2012, MAX 4.x, 5.4, 5.5)
tried to change IP of SB-RIO in static and DHCP mode but not succeded
following screen appear when we tried to change IP and in following screen message every time it indicates "0.0.0.0" ip instead of which we typed or want to change.
any help regarding this issue will highly apreciated.
regards
Message 6 of 12
(7,456 Views)
It almost seems as if something is wrong with the disk.  In order for the target to persist the network settings it needs to be able to write to the disk to persist the setting.  You may want to try manually putting the target into safe-mode, then format it from MAX.  Hopefully, that will fix it, if it is a disk problem.  Then you can try setting the network setting again.
If you continue to see have problems I would suggest connecting a serial cable to COM 1 and enabling console out.  Hopefully, the console will provide some addiitional information to help determine what is going on.
Message 7 of 12
(7,443 Views)
The console out gives the following messages
cRIO-907x Boot
Copyright 2007 National Instruments Corp.
Bootrom version: 2.4.7
Creation date: Jul 9 2007, 00:45:07
Press any key to stop auto-boot...
0
auto-booting...
boot device : tffs=0,0
unit number : 0
processor number : 0
host name : host
file name : /c/ni-rt/system/vxWorks
flags (f) : 0x8
Mounting tffs...
Could not initialize.
Error loading file: errno = 0x0.
Booting into Safe Mode from ROM...
Uncompressing kernel...
done.
2910608
Starting at 0x100000...
Mounting tffs...
Entering safe mode.
Initializing network...
Device 1 - MAC address: 00:80:2F:13:09:62 - 0.0.0.0 (primary)
ERR [KERN] in_arpinput:1232: arp: 54:42:49:70:2e:11 is using my IP address 0.0.0
.0!
.0!
.0!
Message 8 of 12
(7,401 Views)
Ya, that doesn't look good.  Have you tried to format it again from safe-mode?
Message 9 of 12
(7,390 Views)
it gives the following message when trying to format
Message 10 of 12
(7,379 Views)
