08-03-2017 09:38 AM
sbRIO-9651 supports secondary ethernet port eth1 via external PHY usage which is KSZ9031MNXIA. Is it possible to use another 1GBE PHY, DP83867 for example with MDI register access on Linux RT level? Can uboot and/or linux RT drivers be modified to do so?
Thanks!
08-04-2017 04:57 PM
Hey Crowbar,
could you explain more of your project and what your goals are? It's be helpful to have some context with this question
08-16-2017 08:06 AM
I want to use another PHY which supports PTP (IEEE 1588) on a HW level, default PHY doesn't.
08-17-2017 02:31 PM
I haven't found an example of another person doing this. What are you trying to synchronize with the sbRIO via PTP?
