sbRIO Example project failed to open
I have installed the software, and when I open the example at \National Instruments\Embedded Evaluation\Tutorials\1 - Open & Run FPGA Personality\Exercise 1 (Simple FPGA Application),  files under Single-board RIO cannot be saw as the following image. My Computer config is win7(32bit). the single-board is 15B2ECF. I have installed all the software and the single board can connect to my computer successfully.
(5,305 Views)
Hi percy222,
I recommend installing the latest driver version of NI-RIO if you have not already done so.
Provided you are using LabVIEW 2009 SP1 or later, the drivers are located here. (If you are using an earlier version please let me know)
After installing these drivers, update the software on the sbRIO by following these steps, to ensure it matches the version used on your PC.
If you are still experiencing issues after following these steps please let me know.
Chris (CLED, CLA, CTA)
Applications Engineering Specialist
(5,294 Views)
