sbRIO serial port voltage level
What are the RS-232 votage levels on the sbRIO serial ports?  Signal levels could be:  ±3.3 V, ±5 V, ±10 V, ±12 V, and ±15 V?   ±12 V is what i see commonly for direct connection to a PC's serial port.
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(5,541 Views)
Accepted by topic author mfitzsimons
Hi Matthew,
The signal levels for the sbRIO-9605/06/23/26/33/36 are ±5V. I took a quick screen capture of TX W.R.T GND. The voltages in the datasheet spec. ±5.4V (typical) when loaded with 3k and a minum of ±5.0V. The RS-232 standard can accept a pretty large swing however (-3V to -25V) and (+3V to +25V) for the two logic levels. The screen shot I took was with an unloadeed line so the voltage levels appear higher than typical.
The serial transceiver been used is the MAX3243.
Tannerite
(5,534 Views)
No disputing the data.  Thanks for the official answer.
Matthew Fitzsimons
(5,527 Views)
