sbRio-960X
I am looking to design a new Multiplexer Digital using sbRio-960X, not sure what product I need, need some help deciding a product.
I will have a IO board to convert 3.3V IO to 24V sinking and sourcing (256 channels max ) and it will be a separate board.
So the requirements are,
Should have a memory space to run little encoder/decoder to run sinking and sourcing channels from on board 3.3V IOs.
Needs to commutate with another same type of selected sbRio over same subnet.
Also needs monitor (one sbrio board) IO and log in a separate pc in same subnet.
I think I believe use product like sbRio-9606, but I am not sure it is the cost effective hardware and weather it will able to communicate two sbRio-960X together.
Please let me now your opinions.
Ruwee
(5,100 Views)
Hi Ruwee,
Thank you for your post and welcome to the Forums, I have a few questions regarding your proposed application:
  •  Do you wish to read/write data from 256 input/output channels and log the input data on a PC or external storage?
  •  A detailed description of your entire application would be beneficial so I can better determine what it is you are trying to achieve from a high level perspective.
The sbRIO-960x platform is available in OEM (Original Equipment Manufacturer) quantities, in order to determine if this would be feasible considering your application please contact one of our technical sales engineers as they will be able to advise on our full range of hardware in more detail.
NIUK Contact Details
Many Thanks
Jamie S.
(5,090 Views)
Thank you for your Reply, Unfortunately this project has been suspended.
(4,996 Views)
