sbrio device drivers
I want to connect my sbrio9637 to host computer for the first time,
when I installed the cRIO device drivers some driver in following names were installed on my pc,
NI-visa,NI-sync,NI-DAQmx,NI 488.2,IVI compliance package
are the above drivers all I need?because when I plug the board through cross ethernet cable(without any switches in between)  NI device monitor and MAX dont detect any NI boards.
my PC which is in role of host computer doesnt have ethernet port and I ude usb to ethernet adapter can it cause the mentioned problem?
(1,685 Views)
In my experience, it's enough just to install the cRIO device drivers. You can just ignore all the extra stuff. Are you sure you're looking in the remote systems section of NI MAX? Maybe a screenshot would help. Maybe try disabling firewalls. Cross over cables aren't really a thing anymore since gigabit ethernet but they shouldn't hurt either.
(1,645 Views)
I found the problem, I used NI usb-lan adaptor instead of third party company,
(1,635 Views)
