sbrio sntp server
I know it's possible to synchronize a cRIO controller with SNTP server (condition : OS running on cRIO is VxWorks) :
http://digital.ni.com/public.nsf/allkb/F2B057C72B537EA2862572D100646D43?OpenDocument
Is it possible to do the same thing with sbRIO ? (for VxWorks it's OK, it's running on it)
Thank you for any answer,
J.
(6,900 Views)
HI Krsone,
Yes it is possible as with a cRIO.
Refer to  this document (part : Using the System Clock to Provide Data Timestamp)
(6,867 Views)
Thank you for your answer. I'm sorry, I should have been more precise : I'm using sbRIO-9631 and there's nothing in the specifications about SNTP synchronization.
(6,850 Views)
Oups, I'm not using 9631 any more, I'm using sbRIO 9612 : so is it possible to perform SNTP synchronization with this platform ?
(6,839 Views)
Accepted by topic author Julien_31
Yes, the same can be done for the sbRIO-9612. You will just follow the same instruction set as VxWorks based CompactRIO controllers.
Carlton
CLA
(6,693 Views)
Sorry if this thread is very old, I'm trying to configure sbRIO 9642 and 9612 to use SNTP to update their time, and I followed the guide posted above, however nothing happens upon reboot and I see no logs (/ni-rt/system/ts_sntp_log.txt does not exist).
I rebooted, flashed the image again, made sure the NI-timeSync software was included, all to no avail.
Any help would be greatly appreciated.
(4,174 Views)
