scaling a cRIO-9215 AI channel
I am inputing a vdc signal to AI0 on a compact RIO cRIO-9215 module.  I am reading a value from the cRIO that changes as I vary my input, but it is not scaled.  At 1 volt I am getting approximately 3160, at 2 volts I get approximately 6320, etc.  I can't find any properties to scale this value to indicate my voltage input.  I know that I can take my approximate value and do some math, but I was hoping to configure the actual channel.  What can I do?  Thanks.
(3,932 Views)
Hai moynihan,
                          You have to write two different codes one for fpga and other for RT. As i understand you have to use a property in the fpga part for 9215, in that select LSB weight and offset as properties. Then in the RT part you have to use a "convert to voltage vi from the all functions-select a vi menu".  From there you will get the corresponding voltage what you are feeding to the 9215 module. for more assistance go to labview examples from the help menu.
Hope this will clear your doubt.
Labview Lovers.
(3,927 Views)
I've searched and searched but cannot find the covert to voltage.vi.  Do you have a general path?  Thanks.
(3,912 Views)
I found the .vi I needed and everything is working as I need it to.  Thanks very much.
(3,910 Views)
