shared variable libraries
When making shared variable libraries with the CompactRiO, I ran into an issue while making the following:
= An image acquistion VI which obtained images that ran on the real time target
= A display VI that ran on the host.
I created a shared variable which held the image on the host but I found the host VI didn't work. However, when I made a similar library on the RiO, the host VI was able to display the acquired images.
I was wondering if it matters whether the library is placed on the host or the real time target or are both fine?
(3,443 Views)
Did you try to host the Image NSV on the cRIO, create a mirror NSV on the PC and bind it to the NSV on the cRIO.
(3,437 Views)
No. I'm fairly new to the RiO so I don't know how to do that.
(3,433 Views)
(3,431 Views)
