simulation of Controller with Crio 9004
I have the hardware setup of the boost converter ready. Now i want to use the controller I have designed to get the desired output from the plant.
I have designed the controller using SISO controller at the host VI. But I am not able to achive desired output.
The reason I find is the delay that is caused by communication between host nd the FPGA target VI to the AO module.
Is there any way that I can synchronize all these to work simultaniously??
Message 1 of 1
(3,826 Views)
