two triggers with ni4472?
Dear all,
With the DAQ Ni4472.
Can I use the external (digital) trigger and the Analog trigger at the same time. I would like to make an acquisition when the external trigger AND the analog trigger (from CH<1>) are true?
thank you for your help
Message 1 of 9
(7,735 Views)
The 4472 does not support this combined functionality. I do have some ideas how to implement this using some additional hardware. Please contact me directly to discuss this option.
Christian Loew
NI Consulting Services
christianloew@ni.com
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
Message 2 of 9
(7,734 Views)
Some additional information,
This type of application may be solved with the LabVIEW FPGA Pioneer System in conjunction with the 4472. The triggering would be handled by the reconfigurable I/O hardware and the final trigger signal sent to the 4472 over the RTSI/PXI trigger lines. The specific functionality of the trigger can be custom-defined in the LabVIEW FPGA code.
http://sine.ni.com/apps/we/nioc.vp?cid=11834〈=US
Christian Loew
authored by
Christian L, CLA
NI - Austin, TX
Message 3 of 9
(7,734 Views)
And where do I find an example to show me how to route signals onto the PXI Trigger/RTSI Bus from The PXI 7831R FPGA module?
.... and examples for synchronizing multiple cards in two chassis separated by 30m?
Thanks, Louis
Message 4 of 9
(7,637 Views)
Hi, Louis,
If you are using LabVIEW 7.1, you can find an example that routes digital lines over the PXI bus using a 7831R, on C:\Program Files\National Instruments\LabVIEW 7.1\examples\FPGA\Applets\RIO Master-Slave. Basically, you can think of the routing lines like any other digital line of the 7831R. Just be careful and make sure that you do not drive a line high AND low from two different locations at the same time.
I hope this helps!
GValdes
Message 5 of 9
(7,626 Views)
Hi
You may like to refer to the manual on the following link: http://www.ni.com/pdf/manuals/323403a.pdf. I assume that you are using PXI-6653 to synchronize the chassis. This manual explains how to synchronize multiple chassis using NI-PXI 6653 and NI-PXI-4472 cards. I hope so the manual answers your questions.
Aditya Rathi
Applications Engineering
Message 6 of 9
(7,603 Views)
@ADIT wrote:
Hi
Aditya Rathi
Thanks for the routing info - that has helped.
I still am unsure whether or not I need the 6653 for synchronisation. My 2 crates will both have the PXI 7831R in them. I am slowly coming to the conclusion that by routing a 10 MHZ clock onto PXI_CLK through these modules and synchronising the FPGA's to this, I can achieve the desired multiple chassis synchronisation.
... and I am still looking for a driver for my MXI-3 cards for Windows XP.
Thanks, Louis
Message 7 of 9
(7,595 Views)
Louis,
Regarding the driver for MXI-3 on windows XP, the OS will itself attempt to install a driver for this PCI-PCI bridge, but no driver is required. MXI-3 should be detected and configured by the BIOS at boot up. Communication with this PCI-PCI bridge occurs automatically at the hardware level, not at the OS level. The MXI-3 optimization software should be installed on the host PC, but this software is not required to use MXI-3. We would recommend using the MXI-3 Optimization Software.
Aditya Rathi
Message 8 of 9
(7,591 Views)
Hi, One more question - on my PXI 8186 Controller there is an SMB trigger input on the front panel.
I cannot find any info on how to use this to trigger my PXI 7831R modules.
Message 9 of 9
(7,577 Views)
