unsupported item error on RIO
We have a project involving a RIO and a WSN, which was put together for my by a NI value added reseller.  I can see the RIO and the WSN nodes in MAX, and can connect to everything.
When I look at the project view, I get a warning on the RIO (yellow triangle)
Clicking on this I get "The plug in for the selected item is not installed on your system or the plug-in has an expired license, contact NI"
Under MAX, software tab, we are using LabVIEW 2011, with real time installed.
I was told by the developer I may need "Labview for NI wireless sensor networks"
I have the ni_wns_130 installed.
What other driver do I need"
(5,653 Views)
You also need the NI-RIO driver which it sounds like is missing based on the warning in your project. For LabVIEW 2011, you will want NI-RIO 4.0 which you can find at http://joule.ni.com/nidu/cds/view/p/id/2598/lang/en.
Alex Person
NI-RIO Product Support Engineer
(5,644 Views)
Accepted by topic author wreed
Yes!!!!
That fixed it, that was the missing file.  I had RIO version 3, so upgrading to 4 fixed it.
Thanks much
(5,637 Views)
