using DAQ_Vscale for multi channel aquisition
I am trying to use the daq_vscale function for data acquired from 4 channels (scan).
I get the same out put for all channels regardless of demuxing the buffer or not.
(3,934 Views)
Please provide more info.
What type of hardware are you using?
Have you tried using MAX?
Does anything work under any circumstances?
Ben
(3,934 Views)
I am using the PCI-MIO-16XE-10X. It should able me using diffrent gains for different channels. what i don't understand is why the VSCale is not channel specific.
I have max how is it related?
(3,934 Views)
If you look at your channels using MAX do you see the same problem observed in your app?
MAX is a wonderful 1/2 way point that lets you know if the issue is your code, or the software.
Ben
(3,934 Views)
The problem is not the hardware. the problem is the functions DAQ_VSCALE. after I use this function the out put to all the channels is the same (not so before).
(3,934 Views)
