using SMB connector of the 9014
According to the article: Using the SMB Connector for Digital I/O on cRIO-901x Controllers one should ignore the vx_exec.out file. But how to handle the lack of this file? The VI is broken
(3,322 Views)
Hi Przemmo,
If you open the .lvproj file and then try to open the SMB Read or Write VIs, just click on Ignore Item when the VI Loader indicates that it is searching for vx_exec.out. The VI should load without showing a broken arrow. I have tried it myself and it works.
Ipshita C.
(3,316 Views)
Hi Ipshita,
Yes You are right- it works. Thanks. I do not know why it didn't beforehand.
(3,306 Views)
