using a Ni-9203 getting started example
I am using NI-9203 module on a cRIO 9035. For a start, I am following an example "NI 9203 Getting Started.lvproj". When I make an exactly similar VIs given in example, I get several errors, saying broken wires, loose end, etc. Screen shot is attached. I am also attaching the VIs (main and sub vi) and also the project. Can I get help in this regard?
Many thanks in advance.
(2,984 Views)
The issue has been resolved. The errors disappeared after following a specific protocol (provided on ni.com/info) of implementing an example in the project.
(2,955 Views)
